Unplugged the power cord Opened the Control Panel Detached the Control Assembly Cover Disconnected the "Lid Lock Control connection Unable to open in the front - the main top with the putty knife! How to proceed? Ian Nadar E-mail: [email protected]
SOURCE: Cannot figure how to open top cover
The top of the machine does not open. You have to remove the console to get to the retaining clips that hold the entire case on the frame. If you wish to pursue this follow these steps: 1. Unplug machine. It's best not to have any live voltages when working around the console. 2. Lift console. It will come off in one of two ways depending on what type you have. The end caps on either side of the console are removable on some models by popping them off to the expose a screw on either end. If teh end caps don't come off, you will have a retaining clip holding it in place on each side. With this type, you will need to insert a putty knife (from the FRONT of the console) under each corner and push in to release the retaining clip. 3. Once the console has been lifted from the top, carefully lift up and back to its resting position over the back panel of the machine. Use care when when doing so that you don't break the plastic hinges that hold the console in place. 4. There are two brass-colored clips under the console that you need to remove. Insert a flat screwdriver straight down through the top into a groove in the clip and pry towards the back of the machine. This will release the clip. 5. Once the clips have been removed the entire case comes off as one piece. Make sure you disconnect the lid switch connection on the top of the machine first. This will be a plastic white connector plug. Open lid and place one under the front rim of the case and pull from the back towards you. The case will lift off from the back first and off the frame. 6. Replacing the case is always the tricky part. Looking down through the lid of the case, make sure you place the bottom front lip UNDER the frame first and slowly lower the case on to the frame. There are four cleats the must fit back into slots on the frame before it will seat properly. Also, make sure the back fits back into the casing on both sides or the retaining clips will not go back in properly. Insert the clips into the slot on the back panel first then push down on the opening on top of the washer for them to snap back into place. Now, I don't know if you still want to try to tackle this or not. It does seem like a lot, but it really isn't once you get the procedures down. If it's just a simple matter of cleaning because the washer smells, the odor may be coming from the wash tub itself. Running the machine on empty, with the hottest water cycle you can with a cup of bleach can go a long way towards killing bacteria and mildew. Just another thought to save you a lot of effort. Good luck. I hope this helps you.
SOURCE: maytag top load neptune washer error code od
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Hi
Thanks for using FixYa. Error DL indicates door lock failure and it flashes
when either the door lid is not closed completely and/or the Machine/motor
control detects door lid switch is open. To resolve this issue you'll have to
check the door lid/switch if it's fine then replace the machine/motor control
however, the issue seems to be with the door lid. Please rate the solution if
the issue is resolved or post a comment for further assistance.
Thanks
Rylee
