Question about HP Televison & Video
I have a HP PL5060N 50" Plasma TV that keeps turning itself on and off. You can hear it clicking switching the settings but it doesn't give itself enough time for the screen to actually turn on.
    Top Expert:
  • HP Master
  • 55,370 Answers
The power supply is failing.
Posted on Jun 05, 2017
6ya staff
SOURCE:
Anonymous
  • 36 Answers
SOURCE: 50 inch HP Plasma Gone Wild...
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Posted on Feb 04, 2009
livetech
  • 583 Answers
SOURCE: Panasonic 50" Viera plasma on/off problems
its the problem in main board.any of the capacitors or ic are getting overheated that needs to be checked and replaced. thanks.
Posted on Jul 13, 2009
Anonymous
SOURCE: my 50 inch samsung plasma tv turns off and on by
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Posted on Dec 19, 2009
SOURCE: HP PL5060N 50 my plasma will not start, I have a
The "Clicking sound is what gives it away. It would seem that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jan 22, 2010
GySgt2u
  • 63 Answers
SOURCE: tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Posted on Jun 30, 2010
Hp pl5060 Plasma TV has no sound or pix. Screen flashing white
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
Dec 15, 2012 | HP PL5060N 50 in. Plasma HDTV
HP PL5060N inputs problems
If the set has a input or source button on the outside or side it can be got at and removed (not the plastic button but the switch under it) they do fail in this way and with it removed and the issue gone you can use the remote instead.
Nov 06, 2012 | HP PL5060N 50 in. Plasma HDTV
The menu screen comes on and blinks randomly on my hp 50 in. plasma
Reset the set to it factory defaults. Unplug the TV from AC mains wall socket, and replug it after 5 minutes or so. This must make the device to a hard reset. If this do not help you, seek tech support.
Jun 06, 2012 | HP PL5060N 50 in. Plasma HDTV
My hp tv wont turn on
hi it sounds like your plasma has gone in stand by mode look on youtube will tell you all about stand by type in how to fix and tv make model stuck in stand by more than likely capacitors blown if your not any good soldering boards id phone tv guy out but if you are then youtube it hope this hopes
Mar 04, 2018 | HP PL5060N 50 in. Plasma HDTV
Tv keeps turning on and off
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
HP PL5060N 50 my plasma will not start, I have a surge multiple plug, here in Mexico electric surge is very common, when i try to turn it on, it makes a click sound and turn off, It wont even display...
Jan 22, 2010 | HP PL5060N 50 in. Plasma HDTV
Dec 17, 2008 | HP PL5060N 50 in. Plasma HDTV
Televison & Video Logo
133 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
