SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
SOURCE: How do I remove links from an Anne Klein watch
Many watch companies are including extra clasps on the bands so customers can adjust the band easier on their own. Check the bottom of the band for those.
If not I suggest going to a reputable watch repair shop and have them do the adjustment for you. It will save you time and frustration of trying to do it yourself. If a screw or pin drops and you cant find it you may end up having to reorder them from Anne Klein!
SOURCE: where can i purchase 3 extra links for my Anne
Click on my profile, then click on TIPS AND TRICKS, There you will find a phone number for ordering parts from AK. Rate me, plz.
SOURCE: I have an Anne Klein watch and have lost the clasp
Call the following number between 8am and 5pm EST: 1-800-937-0050 ext. 203. You can order watch bands and parts there.
SOURCE: how do i take the
If it's a pop-off type back, (you can tell by running your finger nail around the edge between the back and the case) If you find a slight indent or flat spot near the 12 o'clock position it is a pop-off back. Use a very sharp blade and VERY gently pry the case back up at this spot. It should pop off easily. Don't force it or it'll bend. To replace: line it up in the same position it had been and apply firm pressure untill it snaps back. If it's a screw off back (it has a series of slots around the edge) you'll need a case back tool to remove it. In that case it'll be easier to go to a jeweler.
Testimonial: "very good"
