Try a hard reset to this set, and then check. If it do not help, the firmware might be corrupted, and have to be updated. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply
fails. They are very sophisticated designs that are difficult to
troubleshoot and generally best to just replace the module, but
sometimes there is visible damage in some of the electrolytic
capacitors (visibly bulged) and high voltage rated parts can be
substituted.
Hope Ya Fix It
SOURCE: My G1 is frozen on the android screen
Just manually update to 1.6
Read this, follow the instructions and you should be good to go:
http://theandroidsite.com/2009/10/02/didnt-get-your-donut-1-6-update-yet-heres-how-to-manually-update/
It will put the latest 1.6 Donut Release.
Enjoy
SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This
tip will describe how to perform a hard reset of the device, and how to
backup your 'Favorites' in case the hard reset erases them.
A
hard reset (or Clear All User Data)has been known to resolve unit
quirks and strange behavior after firmware updates. It's generally
recommended to perform it after a firmware update but is not required
by any means. However, if you're seeing quirks and strange behavior
with your unit after the firmware update, it is a good idea to do a
hard reset of the unit. It's also one of the first things that Garmin
will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
Ifpossible
after the hard reset, let the unit sit outdoors in the open for about
30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
SOURCE: My Dell Aero has stuck
Friend,
It seems that the firmware has got corrupted somehow and needs to be reinstalled. Please reinstall the firmware or get it done from Dell Support. Please visit the site below for download and reinstall:-
http://support.dell.com/support/topics/global.aspx/support/aero/dell_aero?c=us&l=en&s=dhs
Here you will find a lot of readable material and lots of FAQs for future reference. Just bookmark the site on your computer.
SOURCE: SAMSUNG WAVE 525 BADA LOGO LOOPING
For this problem contact the mobile service provider......
