SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
SOURCE: LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
SOURCE: Display Becoming White
First, to verify if it is your display adapter, connect an external monitor to your laptop and see if it displays fine. If it is fine on the monitor, then we know that it is from your laptop screen(in this case, it is either you first check from a technician if it is the colour that has to be refilled or if you need to purchase a new screen). If not then it is from your display adapter(could be from corrupt display drivers). In this case, you would have to re-install new drivers for your display adapter(you can download it from your system manufacturer's website if you don't already have it).
Thanks
SOURCE: lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this
happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
SOURCE: LG Screen M227WDP shows only white screen with a version number
Well as you have only had it a few months, SEND IT BACK ( LG does not mean Lifes Good, in the trade we say LG=Lotta Garbage) There have been quite a few chip failures in this model, It should be recalled. Do a warranty call and get it replaced.
please rate my help++++Thanks for using FIXYA
