SOURCE: My Samsung Syncmaster 943BX will not wake up.
You probably have caps failing in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: when ever my computer shutsdown
Sartup repair is some thing that tries to fix the OS issues...
Normally its of no use.. Its better if you can reinstall the OS after getting windows and taking backup of all your important files..
It should be vista or win 7 that you have on the computer then tap F8 when the computer
turns on and then you will be able to see the advanced boot options..
Select repair my computer.. In the repair my computer screen select the
dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you are not able to do this then try to reinstall the OS with the help of a OS CD..
SOURCE: Samsung galaxy s2 tab what type of of micro usb type 2 or type 3.
Per the product sheet at Samsung it is a 2.0 link below
http://www.samsung.com/us/system/consumer/product/gt/p5/11/gtp5113tsyxar/Galaxy_Tab_II_10.1_Spec_Sheets_v13.pdf
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
