I need help with alcatel pixi4 phone when trying to use anything i get screen overlod detected when i open settings aps and press reset nothing happens i dont know what to do
Here are some steps you can try to resolve the issue:
Reset the phone: You can try resetting the phone to its factory settings. To do this, you need to press the "Menu" button, select "Settings," then "Phone Settings," and finally "Reset Settings." This should reset the phone to its default settings.
Update the firmware: If resetting the phone doesn't work, you can try updating the firmware. You can download the latest firmware from the Alcatel-Lucent website . Once you have downloaded the firmware, follow the instructions provided by Alcatel-Lucent to update your phone's firmware. ALCATEL-LUCENT 4029 OPERATION MANUAL Pdf Download ' ManualsLib
If neither of these steps work, it might be best to contact Alcatel-Lucent customer support for further assistance.
From the home screen press the Center key. Scroll to Setting and press the Center key. Scroll to Others and press the Center key. Scroll to Airplane Mode and if off press the Center key. Press OK. Scroll to Off and press OK. Reset the network settings.
Resetting the network settings reconnects your phone to the network and does not erase any of your content or data.
If the problem occurred after you follow the guide, just try to replace your sim. Good Luck!
Try a hard reset which clears everything off the phone and reloads the operating software. You can do back up in the settings and then restore your data.
for alcatel t10 maybe you can try to press the power and volume up button simultaneously and release the button when you see the android logo and there is a red triangle above it and wait till it reboot this might work..we have the same problem but difference is it stays on the lock screen and it never allow me to unlock it if you're experiencing the same problem this reset instructions might not work.
