SOURCE: Splendide 2000 Vented won't work
If you are talking about you have power to the washer/dryer but the machine won't even turn on, won't spin, won't add water, won't turn on dryer, then your situation is like mine right now. Last week with the same situation, we remounted the security switch in the door lock where the little hooks goes into the washer and the machine worked for about a week. Now the same thing is happening and I am looking for a replacement switch.
I definitely need help in getting the washer out of its cabinet and get the cover off in order get to the switch from above.
Jeff
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
SOURCE: We have a Splendide WD2100 washer/dryer
I had the same problem and ordered one from Westland Sales. Phone No: 503-655-2563 Ext. 5 for parts. I believe I spoke to a gentleman named Terry. I just received mine today, cost was $52.00 including shipping.
SOURCE: Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
[email protected]
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
