SOURCE: Flashing Battery Symbol on GPX PDL805
The appearance of a battery symbol while you are using just the battery means that you are using just the battery.
That's it.
No Problem.
The flashing battery symbol is a constant reminder to you that a power intensive function is only supported by the battery, and that you should make external power available so as to complete the task without losing power in a battery drain event.
SOURCE: My IBM ThinkPad showing a black screen with a
That usually means there is a system password that needs to be entered. If you do not know it, you must remove the CMOS battery from the laptop and reset it.
SOURCE: what does a flashing envelope symbol mean in the
it means that u got some messege or ur message memory is almost full.
SOURCE: red light is flashing lower left corner near batte...
that is the battery light, it means you need to charge it.
