I tried unplugging everything except the PSU. still no beeps. The fans are coming on but that is all. Is there anything else i can do to check the MB without wasting much more time?
SOURCE: no boot, got continuous beeps at first, reset my 'savage2000' VGA card
The solution may be to locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
SOURCE: Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
SOURCE: Gigabyte GA-8KNXP not going to POST
You can find leaky caps...
Anyways, those boards have very small inductors that look like caps and are used as pico fuses on most all peripherals and controller chips. Check that they are not blown and replace them with something from DIGIKEY or MOUSER
Also starting with the most simple, check that the power supply itself has not gone into SHOCK. unplug it from mains and TOGGLE the voltage selector switch, MAKE SURE it is back to 110 or whatever you need.
I know it sounds weird but I have resurrected MANY PC's that way.
Other then that it sounds like you are well on your way to finding the defective component on your own. just thought I would throw in the fiew things that have caught me off guard in the past.
SOURCE: no post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
SOURCE: L4S5MG/651+ P4 mother board, no display on power
Hi jayson_rees,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Testimonial: "thanks!!!"
