SOURCE: I have a Marshall channel/dfx footswitch. The jack
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Testimonial: "Great, I'll give that a try now. Thank you so much."
