Computers & Internet Logo
Audrey Shelnut Posted on Jun 19, 2017
Wiring diagram for a viewsonic computer. - ViewSonic Computers & Internet
Circuit diagram-scheme for crt monitor viewsonic p95f+
Schematic diagrams are in PDF, and cannot include here by this window. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
2helpful
Viewsonic VX924 monitor SMPS failed. Replaced all bad capacitors and have found that one pair of inverter driver transistors has failed. They are marked as DKQR (They are apparently Rohm 2SC4672...
When the DC filter caps no longer filter out high frequency AC, that AC will be fed through out the circuits and cause damages such as the inverter frequency will be running at the wrong frequency and caused overheating.
The service manual does not show the sch of the power supply/inverter board because it is not designed by Viewsonic.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound)
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/pdf/UX8623D.pdf - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector. http://www.viewsonic.com.au/support/manuals/files/LCd%20TV/N2750w%20User%20Guide%20English.pdf
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
My viewsonic screen started to buzz. i bought it about a year ago. what is the problem??
well if uses a 3 prong plug to plug it in it may be a ground loop.
try this, goto a harware store and get and adapter to change a 3 prong plug to a 2 prong plug and then plug the monitor cable into that then into the wall.
diagram: power>|'.'|<power
ground
cut off the ground plug and that would also work!
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
1helpful
3helpful
Power-Supply Plug in on Monitor not present ?
wait, is there not a power port? if ther isnt, it may be on the vga port where it connects to the pc, it may of got cut off, your alternative is opening up the mointer and wireing a new power port
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
1helpful
Viewsonic monitor goes blank but you can still here game playing.
I fix a lot of viewsonics and there is no diagrams available to the public as far as I know.
It could be your power board or inverter just needs rebuilding.
It may be a bulb, but usually the boards fail first
ebays bammbammfran
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
