SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
SOURCE: Frigidaire Upright freezer with Beeping Display
the thermistor is most likely bad. you would have to take an ohm reading of the thermistor and check the tech sheet to see if it is in range. The thermistor is $50 to $75 part.
SOURCE: Frigidaire Model # FRS23R4A - Not cooling
wihtout replacing the relay there really isnt any way to tell if its the compressor or the relay. the relay is veyr inexpensive in comparison to the compressor usually less than 70 bucks. and the best part is you can replace it yourself as opposed to paying a service company. this is the part number 218721113 and it prices at 38 dollars thru
sears.com.
once you replace the part if the compressor starts you should be ok. if it doesnt start then you will need to call a service company to replae the compressor or look at replaing the refrig. if the unit is less than 5 years old it may be under warranty for the compressor so check into that first. if I can be of further assistance dont hesitate to ask. thanks Peyton
SOURCE: kitchenaid KSSC42QMS01 refer is beeping. display
three things to check out.
1)the fan wiring's are they getting cut in between or burnt or short.
2)if the wires are proper ,then its faulty fan motor the Fan needs replacement.
3) if the compressor relay is faulty then also fan will not work.the relay is located beside the fan and compressor.
if not familiar with checking a local repair technician familiar with your brand /model is advisable.
to get required parts you can get it from
www.repairclinic.com
or from www.partselect.com
its a common problem occurs many times and checking /replacing the listed parts solves the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
SOURCE: fan runs, but compressor does not start
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
