SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
SOURCE: toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
SOURCE: my toro self propel is not working and the front
check your drive belts are not caught up or broken
SOURCE: self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
SOURCE: My Toro self-propelled lawn mower,
I'll bet the wheel needs to come off, then get cleaned and lubricated. Either that, or a stick or stone has lodged between the wheel and raising/lowering mechanism. Since the mower is a rear-wheel drive, the traction belt/gears are not the problem.
