Hello Margaret Watson,
"Dashes" are not on the trouble list...
See below
My best advice: Call ASKO
Customer Care Center
1-800-898-1879
www.askousa.com
Asko D5424 Operating Instructions Manual Troubleshooting
Carnac the Magnificent
If you need to stop or interrupt a program after you start the machine, turn the Program Control knob
to 10 (Drain). Any water in the machine will be pumped out and you can then press the Door Open
button ( ) to open the door. To restart the washer, close the door and turn the controls to the desired
settings.
On the electronic control models, if you need to open the glass door during a wash or rinse cycle, press and hold the Door Open button for three seconds. The machine will stop and automatically drain enough water so the door can be opened safely. The program will resume when you close the door. The inlet valve will come on to
ensure the proper water level.
In case of mechanical failure, you can use the Emergency Door Opener located by the drain pump. To use the Emergency Door Opener, remove the screw holding the cord handle (loop) and pull the cord down.
Hope this answers your question even if it isn't necessarily the answer you wanted. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
