SOURCE: Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
SOURCE: Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
SOURCE: Washer fills with water then does nothing
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
SOURCE: roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
