Question about Tablets & eReaders
Utilize sd card for apps on yuntab tablet, I have no room to download and app from play store
    Top Expert:
  • Tablets & eR... Master
  • 85,223 Answers
Most apps can't be downloaded to an SD card.
Posted on Jun 26, 2017
Anonymous
SOURCE:
How move downloaded apps to sd card
call your cust service for the manufacturer of your device
Dec 26, 2015 | Tablets & eReaders
My tablet won't let me download any apps. Says it's parsing??
Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
Jul 04, 2015 | Tablets & eReaders
When I want to install more apps says I have no more storage.yet I do .what's wrong Storage says available.
On your internal storage SD card there is an App partition. This is where all your apps are stored. Many devices have a small App partition like maybe 1 gigabyte. It doesn't take long to fill this up with additional apps.
Many Android devices display this App partition storage bar graph in Settings > Storage. It's usually the top horizontal bar graph. If it's all one color then it's full and it will perhaps say something like 1 gigabyte of 1 gibabyte used. The only way to get
more room to download new apps is to delete some of the old ones, or in some case a few of them might be able to be moved to the external SD card if your device has one in its slot.
May 21, 2015 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
Ok I have a zeki quad core tablet and a 8gb SD card and I'm wanting to download games from my tablet to the card how do I do it ? 2question once I do that how do I how do I synce them into my Motorola...
Brittaney
You should download apps from Google Play Store to your phone. You shouldn't attempt to put them on an SD card. The play store ensures only compatible apps are installed.
Mark
Motorola Support
Mar 16, 2015 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
This tablet has 2 lots of memory,one called endeavour which has 4.83gb,and one called internal which has 142mb free.I want to update a few apps but it tells ,e I haven't got enough room! How can I upd
not exactly sure - but some tablets designate internal stg for the operating system and built-in apps and data such as address book or contacts, the settings app, etc. the endeavor stg may be the remaining available for your apps, data and media. Some updaters require extra working room to update an app - look in your settings and see if you set a default location for the apps and media you install. Another thing you can try is to delete the app and then reinstall it from the play store, the reinstall should grab the latest version. It also looks like you can add memory via SD card - probably a micro SD - 16gb is fairly inexpensive. Insert the card then mount it - look in your settings to see if you can set it as your default location or if it is offered as a choice when attempt to install an app. Some operating systems only allow media such as music, photos and videos to be stored on SD card memory - if possible, do a google search for your tablet model to find a manual.
Dec 10, 2014 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
I tried to download showbox on to my zeepad tablet but now every time I try do to download something from the Google play store I cant
You might want to free up internal storage space on your android tablet. You can do this by moving some apps to an SD card that you have installed. Go to your app drawer, tap and hold on an app, and drag it to "App Info". Then tap move to SD card. Another way to free up space is to uninstall apps that you don't use anymore. If that still doesn't work, try installing a storage cleaning app. I would recommend SD Maid by darken. Hope this helped!
Dec 01, 2014 | Tablets & eReaders
Transfer data from galaxy 10.1 note to sd ext storeage
Go to the play store and download a file management app. Use the app to move the files. OR, connect to a PC and manually move the files to the SD card
Dec 27, 2017 | Samsung Galaxy Note 10.1
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Feb 01, 2018 | Tablets & eReaders
Tablets & eReaders Logo
278 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
