SOURCE: Arching in Picture tube socket
ok! the arching line is for screen grid, make sure your spark gap is in align! or much better replace a new one CRT socket then clean all CRT board area with laquer thinner...
SOURCE: 32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
SOURCE: can you replace the picture tube on a big screen maganavox tv?
yes it can be replaced.but the tubes are costly to get replaced.you can get the parts at www.partstore.com or at www.shopjimmy.com thanks.
SOURCE: No picture, high voltage cable sparks at left tube/gun at turn on
It sounds like you have a shorted picture tube.
You should call a good TV Tech to confirm this and get an estimate.
SOURCE: when i turn on tv it blinks 7 times no raster and
You have a power regulator fault and it shuts down to reduce the X radiation from the tube.
Check the 135Volt line!
