SOURCE: laptop ram support....
windows xp will support 2gb
Wndows Vista is 4gb
please rate this fixya
SOURCE: hi i have acer aspire
According to Acer your system can support a max of 4 gb RAM. It has 2 slots so you would need 2, 2 GB RAM modules. Hope this helps & please remember to rate my answer. Thanks.
SOURCE: what is the maximum amount of memory supported by this motherboard?
The 085ch Mobo, which is found in the HP D530 CANNOT support up to 4gb, Only 2 gb
Chipset nVIDIA nForce2 400 + MCP
Processor AMD Socket 462 on board.
Front Side Bus 400/333/266MHz Front Side Bus.
Memory 2 x 184-pin DDR DIMM Sockets.
Supporting unregistered non-ECC DDR 400/333/266/200 DRAM up to 2GB.
SOURCE: what is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
~To download the manufacturers and
therefore correct drivers
or specific software;
Always get your drivers
from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the
manufacturer's
web site, usually one is able to download if
available, by model number,
All available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing.
This is the best way of ensuring up to
date drivers for your system and they are free of charge!
There
are no XP drivers to be found with Microsoft as XP is no longer
supported.
Some
manufacturers may have a limited number of Drivers still listed.
I hope this helps.
8 GB.
