SOURCE: Outlook express6
if you are trying to send an email from an old isp mail account, using a different isp email connection; you have to change the mail.smtp settings, for the settings you will need to refer to your isp. If you are trying to send an email using a hotmail account, this can no longer be done as hotmail no longer allow the use of outlook express with their accounts
SOURCE: Facing problem with outlook plz help
Either the message you are trying to send is too big, e.g contains a too large attachment, or your mailbox on the server is full...
SOURCE: Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
SOURCE: I can't update microsoft outlook connector, I
Try to update it in safemode (press F8 at bootscreen until "Start in safemode shows, safemode with network if you dont have the update-file on your computer).
Or you press ctrl+alt+del and klick the process-tab. When you have all running processes shown, try to find which one is for Outlook and turn it off.
I don't use outlook so I don't know the name, but try the ones you think, worst thing that can happen is that you have to restart your PC.
SOURCE: Trying to setup Microsoft Office Outlook getting
the problem should get solved by going to your email account settings (Tools > Account Settings > More Settings), and checking the "My outgoing server (SMTP) requires authentication" option.
