When i turn my nextbook tablet on, it says "there's an internal problem with your device, and it may be unstable until you factory data reset." what does this mean?
you are having trouble resetting your Nextbook 8P. Here are a few steps you can try to reset your device:
Soft Reset: Hold down the Power button until the device turns off, then turn it back on.
Factory Reset using the Settings: Go to "Settings," then "Backup & reset," and finally "Factory data reset." Confirm the action and wait for the reset to complete.
Factory Reset using Hardware Buttons: If you are unable to access the settings menu, you can try resetting the device using hardware buttons. To do this, you will need to follow these steps:
Power off the device
Press and hold the Volume Up button and the Power button
Release the buttons when the Nextbook logo appears
Press the Volume Down button to navigate to "wipe data/factory reset" and press the Power button to select it
Confirm the action by pressing the Volume Down button to select "Yes" and the Power button to confirm.
If none of these steps work, the device may have a hardware issue and it may be necessary to contact the manufacturer or a professional repair service for further assistance.
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
make sure you do this right or you could end up in more trouble.
if you are not sure what to do then dont do this.. Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.20 Aug 2013
Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe datanavigating with the volume buttons and then to wipe data
If you synced your tablet with your computer you can restore the device with the computer you last synced with. it allows you to reset the password and re sync your data or restore the back-up. Or you can do a master reset by holding the power button and down volume until the menu appears then choose restore factory reset, you will loose all apps that you have downloaded. remember to remove the SD card before you do the reset.
this is an easy fix, 1. with the tablet off, press the power and vol up buttons together until unit comes on.2. using the volume buttons select wipe data/factory reset and use power button to comfire. once tablet restarts it will be just like new out the box. hope this helps
You'll need to do a factory reset: 1.
With the device off, press and hold Volume
Up and Power.
2.
Release the Power button when you see the logo, but continue
to hold Volume Up until the recovery screen appears.
3. Use
the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4.
Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
