Frigidaire Model FGEW2745KFB Serial Number NF30826819
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
SOURCE: 1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
SOURCE: SELF CLEANING MAGIC CHEF OVEN BOUGHT 24 YRS AGO
That's fairly typical but I would suggest removing the shelves and cleaning those with oven cleaner if they need it at all.
Expect the door to remain locked for additional hours for safety.
The temperature rises to > 900 degrees F and is necessary to start the catalytic process that consumes the crud.
Sorry I didn't see your message earlier-
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
SOURCE: My Microwave oven makes a loud buzzing noise and
Quite
often this is due to grease or food particles stuck somewhere in the
cavity of the oven or stuck on or behind the waveguide cover.
The
waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the
size of a playing card and often held in place by a plastic rivet.
In some models it is a
larger stirrer cover type made of thicker plastic in the ceiling of the
oven.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
If your
waveguide cover
is burned, it will need to be replaced.
It provides critical
protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download owner's manuals
and installation instructions for Electrolux and Frigidaire
here.
Otherwise, you can find links to helpful exploded view
diagrams and part ordering help
here.
I recommend that you bookmark that
link to your favorites.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
