Washing Machines Logo
j
john murphey Posted on Jul 01, 2017
The door on my ASKO WL6532XXL won't open. - Asko Washing Machines
Asko D5436SS Under Bench Dishwasher. The handle cover has flopped.
Question edited for clarity, add maker.
Question moved from Car and Trucks.
Here is the service manual.
https://www.frontloadbearings.com/asko-dishwasher-3-000-5-000-series-service-training-manual/
How do I replace the the door latch on an asko dishwasher
JustAnswer https://www.justanswer.com > Appliance Repair
Dec 23, 2009 - Just open the door, remove all the screws around the door panel and control panel going around the inner door liner. Remove the 2 screws going ...
1 answer · Top answer: very easy. Just open the door, remove all the screws around the door panel an
Generic video for Smeg
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Asko WL6532XXl error code LE
Yup, LE is the door latch. Seems like at some point the solenoid gets too weak to push the switch that tells the washer the latch is really closed and it cuts power to the latch and won't operate.
The door latch is fairly easy to repair. I've done it twice and I'm just an intermediate DIYer. The latches seem to fail every 3-4 years. You pull the rubber ring and the metal ring from around the door, then undo those two screws you can see around the latch. Then unplug. Then reverse. Unlike many instruction videos for other ASKO models, you do not need to pull the front panel off to do this. Just the rubber ring and huge retaining ring that holds it in place.
The confusion right now is finding the parts because no one SEEMS to have them in stock, but they are easy to get, if you don't bother with google to find them, because you won't find them there. Sub Zero has exclusive rights to distribute Asko parts in the US now. So you have to go through them. If you use google you will find "out of stock" and "discontinued" on the listings of everyone else who used to be allowed to sell them. The official distributors aren't google friendly, I guess.
If you are in New England, you can get parts from Certified Appliance Parts if you are in the Mid Atlantic you have to go through Mid-Atlantic Parts Distributors. If you are elsewhere, search for "sub zero parts" and your state. The right place should come up.
You need ASKO item #3619046410 Door latch It cost me $43.3091b107-adb1-46a6-88c7-2854451f7a6f.png
1helpful
2answers
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
1helpful
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Door won't open
has your machine got a filter that is exsessable if so you need to undo it and empty the water,( before the door will not open with water in the drum its a safety device if the filter is not on the front of your machine you will need to find it and clean
4helpful
3answers
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
2helpful
Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
