SOURCE: remove password from award bios on asus laptop
Click on the link below and follow the instruction
http://www.fixya.com/support/r1257563-break_bios_password
SOURCE: forgot asus laptop password Windows vista
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
SOURCE: Eee Pc 4g Asus BIOS password forgoten
this passsword can be onky given by your coustmer service center
SOURCE: how to clear bios password for my asus laptop i
You will need to disassemble youre laptop and get to the cmos battery. This is located in the bottom right hand corner of the inside of the laptop and looks similar to a watch battery. Do not have your laptop plugged in being charged and have the power shut off. Take out the battery and disassemble the laptop. Leave the battery out for about 30 minutes to reset all bios settings, including your password. This should work and you will then be able to enter into Windows.
SOURCE: I forgot my bios password
need to open the laptop and remove the BIOS battery and put it back after 10 seconds
