Do I need to access the old valve from the rear of the machine? I cannot get a tool in from the front to undo the water inlet hose and it is screwed up really tight
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
SOURCE: Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
SOURCE: Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
