W
William Porter Posted on Jul 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installing cartridge ribbon on a Royal Alpha 2001 electric typewriter
James Cagle
Level 2:
  • Expert 482 Answers
  • Posted on Feb 11, 2018
James Cagle
Expert
Level 2:
Answers
482
Questions
6
Helped
100281
Points
575
The cartridge should lift up and off then the new one is put in
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
  • Posted on Oct 29, 2007
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Anonymous
  • Posted on Jan 27, 2009
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Dick O Reilly
  • 3594 Answers
  • Posted on Jun 11, 2009
SOURCE: How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
squipps
Mike Wheeler
  • 204 Answers
  • Posted on Dec 19, 2009
SOURCE: How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
squipps
Mike Wheeler
  • 204 Answers
SOURCE: Need to re-set margins on Royal electric typewriter
Use the green code key with the rm and lm keys.
How do you change the ink cartridge ?
Lift the carriage cover. Take note of the position of the ribbon in the ribbon guide and squeeze the ribbon cartridge sides while pulling straight up. When installing the new ribbon cartridge, make sure to seat it properly with the ribbon captured in the ribbon guide. Close the carriage cover.
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
How do you remove the ink cartridge from a Royal Alpha 2001.
If memory is working there is a lever with a red end just to the R. of the ribbon, pull it toward you untill it stops the ribbon cassette should lift out.
DickyO
1helpful
2answers
Top Royal Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
