SOURCE: blue wire not fitting in modem
I assume that you are trying to plug the cat 5 cable into the pc and thats where you say its to big. The port your'e trying to plug it into is likely the modem but its not the modem that you want to connect it to. You want to plug it into the network jack on the pc. The modem connection is smaller than the network connection. Most newer pc's come with it already installed, but if you have an older pc that doesnt have a network card then you will need to add one. Take a good look and see if there is another jack that it will fit into.
SOURCE: Sansui SV 2938 picture disply too big for screen
first is that tv have a tube if it does take back off and you will see what looks like a large light bulb tube and theres a clamp or two maybe even three clamps holding it inside the main big tube loosen the clamps being carefull not to get shocked by touching the wrong thing and the tube will slide back and forth it will also turn so place a mirror or just try looking around it when you adjust the tube to the correct messurement and make sure its level then lightly retighten screws be very carefull not to crack tube by over tightng hope this helped
Testimonial: "Thank you for the advise. Will try it and let you know.... "
SOURCE: were can i buy screens for rear projection tv's?
Sony does not reveal the parts manufacturer. If you really want the part of the TV, please contact PAS at
1-800-488-SONY (7669)
Hours of Operation:
Mon - Fri 9:00AM - 10:00PM EST
Sat 10:00AM - 7:00PM EST
Sun 12:00PM - 6:00PM EST
SOURCE: My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
