Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: unlock LG VX9100 by verizon
is the main screen locked? if it is the password is usually the last 4 digits of your phone number or hit the lock button
SOURCE: Is it impossible to unlock the new lg prime from
You
can
get the unlock code by contacting your current service provider
customer care department.If your phone is locked you can use any of
your friends phone to make this call. The
service
provider will then provide you the unlocking codes.
Remember
that the reason why the codes are provided only through customer service
provider is they will make a check on your name and identity proof at
the time of your call. If the information is found to be correct and
matching with their data then you will be provided with the codes.
Everything is done for free of cost and you are not going to be charged
for this process.This
is
the universal solution and is useful for many customers who are
facing these kind of problems. Don't believe in any websites which
provides unlock codes. All are fake. Only your service provider can
provide these codes.
Another alternative is, you can take the
phone to any authorize phone service center to help unlock the phone,
because to unlock your phone, you will need some kind of software, USB
cable
etc to unlock the phone, so you can also go a nearby phone service
center to unlock the phone,
but calling your network service provider is the best because they have
the records of your phone and can easily help to unlock it.
Take
care.
SOURCE: Need to Unlock LG SHINE CU720 from ATT
First, don;t change your sim card with another sim card from other network before you unlock your phone. To unlock your phone in this case you need lg shine cu720 unlock code and you can get that from your service provider. Other option you can buy lg unlock code from online unlock code store.
