SOURCE: My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
SOURCE: maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
SOURCE: I have a MayTag 5000 with steam washer /dryer.I
Dear I'm sending you an email I got and refer to offen. Give peroxide a try 50/50 mixture with water. It can't hurt and i hope this helps you.
Peroxide, who knew? *
(Safer and Healthier than Bleach)
This was written by Becky Ransey of Indiana (a doctor's wife), and I want to share it with you. She was over recently for coffee and smelled the bleach I was using to clean my toilet and countertops. This is what she told me...
I would like to tell you of the benefits of that plain little ole bottle of 3% peroxide you can get for under $1.00 at any drug store. What does bleach cost?
My husband has been in the medical field for over 36 years, and most doctors don't tell you about peroxide. Have you ever smelled bleach in a doctor's office? NO!!! Why? Because it smells, and it is not healthy! Ask the nurses who work in the doctor's offices, and ask them if they use bleach at home. They are wiser and know better!
Did you also know bleach was invented in the late 40's? It's chlorine, Folks! And it was used to kill our troops. Peroxide was invented during WWI in the 20's. It was used to save and help cleanse the needs of our troops and hospitals. Please think about this.
1. Take one capful (the little white cap that comes with the bottle) and hold in your mouth for 10 minutes daily, then spit it out. (I do it when I bathe.) No more canker sores, and your teeth will be whiter without expensive pastes. Use it instead of mouthwash.
2. Let your toothbrushes soak in a cup of peroxide to keep them free of germs.
3. Clean your counters and table tops with peroxide to kill germs and leave a fresh smell. Simply put a little on your dishrag when you wipe, or spray it on the counters.
4. After rinsing off your wooden cutting board, pour peroxide on it to kill salmonella and other bacteria.
&a mp;n bsp;
5. I had fungus on my feet for years until I sprayed a 50/50 mixture of peroxide and water on them (especially the toes) every night and let dry.
6. Soak any infections or cuts in 3% perox ide for five to ten minutes several times a day. My husband has seen gangrene that would not heal with any medicine but was healed by soaking in peroxide.
7. Fill a spray bottle with a 50/50 mixture of peroxide and water and keep it in every bathroom to disinfect without harming your septic system like bleach or most other disinfectants will.
8. Tilt your head back and spray into nostrils with your 50/50 mixture whenever you have a cold, plugged sinus. It will bubble and help to kill the bacteria. Hold for a few minutes, and then blow your nose into a tissue.
9 If you have a terrible toothache and cannot get to a dentist right away, put a capful of 3% peroxide into your mouth and hold it for ten minutes several times a day. The pain will lessen greatly.
10. And of course, if you like a natural look to your hair, spray the 50/50 solution on your wet hair after a shower and comb it through. You will not have the peroxide-burnt blonde hair like the hair dye packages but more natural highlights if your hair is a light brown, reddish, or dirty blonde. It also lightens gradually, so it's not a drastic change.
11. Put half a bottle of peroxide in your bath to help rid boils, fungus, or other skin infections.
12. You can also add a cup of peroxide instead of bleach to a load of whites in your laundry to whiten them. If there is blood on clothing, pour it directly on the soiled spot. Let it sit for a minute, then rub it and rinse with cold water. Repeat if necessary.
13. I use peroxide to clean my mirrors. There is no smearing, which is why I love it so much for this.
I could go on and on. It is a little brown bottle no home should be without! With prices of most necessities rising, I'm glad there's a way to save tons of money in such a simple, healthy manner!
This information really woke me up. I hope you gain something from it, too.
Pass it on! If you'd like to.
FROM ONE OF MY FRIENDS TO ANOTHER.
