SOURCE: to remove and replace replace timing belt on a ford laser/mazda
which belt what is it driving powersteering? some times the tensioner pully is acessible from the bottom under the car or hidden at a not so easy place to get ur hands just follow belt and keep looking
SOURCE: how do I release the belt tension pully to replace serpentine belt
You can run down to your local auto parts store and buy a serp belt tool. Or you can take a 3/8 drive ratchet, locate the 3/8 square hole in your tensioner and put the ratchet in the hole. For more leverage I put a deep socket over the ratchet handle and put a long 3/8 extention in the deep socket. This will provide ample leverage and will save buying more tools you do not need. Simply move the tensioner to the direction that takes pressure off of the belt.
SOURCE: 1995 ford taurus,broke bolt on tensioner pully while trying to replace belt, now what??
was this the bolt in center of the tensioner pulley? if so you will need to remove and replace the tensioner assembly, if not which bolt did you break?
SOURCE: Huskee LT 4200 modle 13aj771g031
Set the brake/clutch. This will disengage the linkage that tensions the main drive belt, allowing you to put it on the pulley.
I hope this is helpful.
