SOURCE: Frigidaire Front Load Washer Problem
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
SOURCE: Kenmore Elite front loading washing machine
My machine just died. No codes, no nothing. I thought it had blew a fuse. But the outlet is fine. There is no power to the unit. There is a load in the machine and I can't get it out. Help
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Hello friend, thank you for your post!
I see that your Frigidaire washer, FAFW3517KW, is constantly showing you pause, when you press start it flashes the pause again, and that the door lock light does not come on. You could be seeing a couple of different possible reasons this is happening such as your control panel, door lock assembly, or door switch. Since it could be any of the underlying issues I would recommend having a professional come out to the home and repair the washer. -Matt
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
