Computers & Internet Logo
A
Anonymous Posted on Jul 11, 2017
I have asus q200e and its window locked how to bypass
Need to download operator manual for Asus q200e notebook pc
Asus suport page for the q200e is here https://www.asus.com/support/Download/3/482/0/1/41/
Forgot password
try pressing F8 on boot up and go into safe mode select admin account and log in to user accounts and change password for the account locked out or create new account that will at least get u back into windows search net for key unlocker programs thanks
Touchscreen does not display
YOU DROPPED IT, THAT EITHER BROKE THE MONITOR OR THE CONECTION TO THE MONITOR BUT YOU SAY THAT WHEN YOU HOOK UP TO A MONITOR IT WORKS OK.YOU CAN FIX THE PROBLEM YOU GO TO E-BAY AND TYPE THE NAME AND MODLE NUMBER ONCE YOU ARE IN E-BAY LOOK FOR THE ASUS Q200E AND YOU ARE LOOKING TO BUY ONE FOR PARTS WITH A GOOD SCREEN...[REMINDER IT WOULD HELP IF YOU GET A PAY-PAL ACCOUNT.AND MAKE SURE YOU HAVE A MINI SET OF PHILIP SCREW DRIVER AND A MAGNET TO KEEP SCREW TOGETHER.
AND PAY CLOSE ATTENTION WHEN DOING THE REPAIR
PLUS YOU'LL HAVE EXTRA PARTS.
GOOD LUCK.
Can't seem to get Asus Q200E Tablet to let me do a clean Install of windows 7 from a flash drive is there something I'm forgetting
there should be an area in the bios to change the boot order. In this you will want to put the usb as the first in the boot order.
Asus q200e boot problem
When you are in the BIOS see if the HDD is present. If not then it's probably the root cause of the problem because the system has nothing configured to boot to.
Locked keyboard on windows 8 with asus q200
well I know something that might work. don't shoot me if it doesn't.
first of all, make sure you're laptop isn't charging, then take out the batery from the underside. then press on the ON button for about 30 sec. when you've done that you can put the batery back in and start your laptop. your keyboard should be working.... hope it helps :)
My asus q200e was restarting almost one day?how to reset my notebook
In Order to reset the unit you will need to power the pc off and Tap on the F9 key while powering up <> if not let me know
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
