We have had the problem fixed before - a couple of years ago. The repair person said that when it next happened the motherboard might need to be replaced? Wondering if anyone knows what the problem is and how to fix it?
SOURCE: red/pink shades in dark areas happens only 6ins down from top
i'm having the same problems, in the dark areas i get a red shade. has lg or anyone else figured out how to fix it, if so your help would be appreciated very much. also i have my pc connected to it and having the same problems.
KOne
SOURCE: screen flickers on Mits 62825
question one.. is there and audible whine like a bad motor.. THIS could be a color wheel. this mechanical wheel provide the color for the set. This is the first possiblity for the symptoms you describe
SOURCE: LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
SOURCE: Our display board was replaced now the y sustainer board needs replaced
Three suggestions:
Contact http://www.ptscorp.com/television.html. They have a selection of replacement boards or will repair it Fees are usually $50 to $125 and I have had great success with them.
Another would be to try www.shopjimmy.com and lastly do a Google search, if you know the exact part number, to find other sources for the board.
