Look frr this little guy it needs to be cleaned occasionally
Candy GO482 Washing Machine Drain Pump Filter eBay AFTER SALES SERVICE
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
