SOURCE: MY tV will not power and red light keeps blinking
http://www.keohi.com/keohihdtv/brandspecific/toshiba/quickfix/flashing_led.html
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor
from power and from computer and test computer with different monitor
to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing
led on front of the monitor , and monitor turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or a broken contact, identified an internal fault and kicked in
, starting the flashing light.
If
you are in situation one, then the monitor will reset just unplugging
power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults
that can occurr are a blown capacitor on power board, faulty inverter
board, faulty input board, or a fault on LCD Digital Controller board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: My Lg Monitor wont show screen (Power Button Flashing)
1The
protection circuit.
If
Common
faults
that can occur are a blown capacitor on power board, faulty inverter
Check also
can get same flashing state because of the video cable.
SOURCE: No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too. Dave
