Hello!
"SE" error basically means:
High/Low voltage detected.
How to resolve:
Restart the cycle.
If the code reappears, call for service
I also add a link to the manual to a Samsung washing machine. Hopefully, it will help :)
http://manualsbrain.com/en/manuals/1797935/?page=33
SOURCE: Samsung J845 error SE or 5E
I found the manual! The error is '5E' and, according to the manual, the fix is to clean the filter in the bottom front of the machine. But it took a bit more to fix my machine. Here is what I had to do...
First, use a coin to remove the cover on the bottom right hand corner of the front of the machine. Then you will find two cover or plugs, one big and one small. The small one is the 'emergency drain', the big one is the 'filter'.
Pull on the emergency drain plug and you will find that it is attached to a black rubber hose. Pull this out until it is fully extended, about 15cm. Then twist the plastic plug out of the end of the of the hose. Water should run out of the hose and (eventually) drain the bowl.
If no water comes out then the hose is either kinked or blocked. If the hose is fully extended then it is probably blocked. Twist and remove the big (filter) plug. A small barrel shaped filter is attached to the back of this plug. Lots of water will probably rush out if the drain hose is blocked. Make sure the filter is clean by washing it under running water.
Remove any debris that is in the cavity. When you look into the hole where the filter goes, there is a propellor right at the back, a small hole in the bottom and a larger hole on the left side. Make sure the is no debris in any of these places. Also make sure the propellor spins freely.
I had sand and small gravel filling the small hole in the bottom of my machine. It is nearly impossible to pick this out of the hole. However, this is the hole the goes to the black rubber emergency drain hose. Mine was completely blocked with sand, etc. I scraped what I could out of the top of the hole, but couldn't get much deeper than about 10mm. So I blew (very hard) into the black hose. It took some effort but eventually the sand and stuff burst up out of the hole.
To fully flush the hole and hose, I started the machine on rinse. The water starts to go into the bowl and after a few seconds water comes rushing down the hole in the left side of the filter cavity (and out all over the floor!) this also lets water go down the hole to the drain hose. I blew into the hose again a couple more times and the water bubbled up out of the hole and it flushed out the hose nicely.
The propellor was clear, but I can remember previously removing a hair pin from it, so make sure it is spinning freely and if not look for something stopping it.
Also check the hole on the left side. I found a curtain ring jammed up in there. It took sime getting out. I had to get a wire coat hanger and shape it into a hook that I could feed up the hole a little way. Then I was able to pull the curtain ring out. I could feel the ring with my finger, but couldn't get hold of it. When I got the wire hook on it, I had to pull hard to get it out, but it eventually came and (I don't think) I did any damage to the machine.
Once I had cleared everything out of the filter cavity, I made sure the water all flowed nicely. Then I put it back together and it has been working fine every day since.
I hope this helps others one day. I also have my manual again; if anyone else wants to check it out let me know.
Regards,
Greg
SOURCE: Please help! My samsung 7kg J845 front loader
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
SOURCE: getting error 5e WF7708 samsung front loader. Have
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Testimonial: "i was draining the water out only coming out in dribbles so i think you hit the nail on the head....ty ty will give it a go..."
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
SOURCE: my samsung 7kg front loader keeps flashing UE on
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
