Garden Logo
Posted on Jul 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toro 74630 replaced broken idler pulley, belt OK. mower will not move. all looks like it is all working properly
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
  • Posted on Nov 02, 2018
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
112275
Points
562
Belt may be routed incorrectly
5 Related Answers
Anonymous
  • 481 Answers
  • Posted on Jul 20, 2008
SOURCE: idler pulley arm
there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
Anonymous
  • 362 Answers
  • Posted on Feb 09, 2009
SOURCE: Serpentine belt routing
Here you go.. I looked up the same belt you did, it should be right.
Anonymous
  • 15935 Answers
  • Posted on Apr 26, 2009
SOURCE: Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
  1. Disconnect the negative battery cable.
  2. Loosen the A/C compressor mounting bolts.
  3. Pivot the A/C compressor towards the engine in order to relieve the tension on the belt.
  4. Remove the A/C compressor drive belt from the pulleys.
To install:
  1. Properly route and install the A/C compressor drive belt on the A/C compressor, the power steering (if equipped), and the crankshaft pulleys.
  2. Adjust the A/C compressor drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the A/C compressor mounting bolts to 13-20 f t. lbs. (18-28 Nm).
  4. Connect the negative battery cable.
Alternator Belt
  2. Remove the power steering pump and the A/C compressor drive belt.
  3. Loosen the generator mounting bolts.
  4. Pivot the generator towards the engine and remove the accessory drive belt.
To install:
  1. Properly route and install the generator drive belt on the pulleys.
  2. Adjust the alternator drive belt to obtain 6-8 mm (0.24-0.32 in) deflection for a used belt or 5-6 mm (0.20-0.24 in) deflection for a new belt.
  3. Tighten the generator mounting bolts to 17 ft. lbs. (23 Nm).
  4. Install the power steering and the A/C compressor drive belt.
  5. Connect the negative battery cable.
Power Steering Pump Belt
  2. Loosen the power steering pump mounting bolts.
  3. Pivot the power steering pump towards the engine in order to relieve the tension on the belt.
  4. Remove the power steering pump drive belt from the pulleys.
To install:
  1. Properly route and install the power steering pump drive belt on the power steering pump and the crankshaft pulleys.
  2. Adjust the power steering pump drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the power steering pump mounting bolts to 22 ft. lbs. (30 Nm).
Dwain Pippen
  • 377 Answers
  • Posted on Jun 28, 2009
SOURCE: MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Anonymous
  • 389 Answers
  • Posted on Sep 30, 2009
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Toro TimeCutter Z17-42 Zero-Turn Riding Mower is breaking belts!
Question edited for clarity, full 'make model (what it is)'.
Question moved from Cars and Trucks category to correct Toro.
In that scenario, the clutch jamming and locking up against something may be a possibility. If the clutch just jams it holds the blades on contact with the drive.
Worn pulleys, badly aligned pulleys, or sticky bearing are much more likely. There is lots of help here as this is a known issue.
https://www.google.com/search?q=Toro+timecutter+breaking+belts
Why is my belt keep falling off
Hi Kenneth:
There's a good chance that one of the pulleys has a problem.
With the engine OFF, lie so that you can see the belt and pulleys. 1) Try to move the cutter pulleys while holding the blade. Any movement will indicate a stripped or loose connection.
2) Have a helper move the engage lever back and forth so that the belt pulls against the pulleys. Look for any unwanted movement like wobble in the pulleys.
3) Check the idler pulleys to make sure the bearings are OK.
Jul 05, 2015 • Toro Garden
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
How do I replace the belt on a toro ss5000 #74630 timecutter
Go to you tube On the line replace belt toro etc.
Jun 21, 2014 • Toro Garden
Drive belt broken
if your self propel belt is broken use pry bar to push idler back and remove belt from pulley then go under deck and weave belt from around shaft and blade.
How do i keep the belt from slipping off
what kind of mower? generally there should be a spring loading idler pulley to give it tension and/or the pulleys or out of alignment or worn out what i would do first to look at if the belt has the proper tension should only able to move 1/4 inch up or down
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
How do I replace the belt on my toro model 20334 lawn mower
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from comming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
4helpful
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 • Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
