SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
SOURCE: Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
SOURCE: Samsung Flat screen 100hz tv - no power
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
SOURCE: Viewsonic flat screen tv. That
No there are no fuses in that type of flat screen TV. If it will not power on at all then it sounds like a failed or at least failing power supply inside the TV.
Unfortunately this is a very difficult repair, and unless you are an
electrician I would not recommend attempting it. You will want to
contact a local TV repair person in your area if you are sure this is
out of warranty, more on that in a bit here. This is actually the
most common problem with this type of TV, I see it every day, it just
happens - sometimes with new TVs and sometimes it takes many years for
it to happen.
If you think it may
still be under warranty please contact the manufacturer to file an
RMA. If you happened to purchase the TV with a major credit card (not
a debit card) there is a good chance it may still be under the free
extended warranty most credit cards place on electronics. Please
contact your credit card company to inquire if they do this, and they
will be able to file the claim and get you a refund for the TV.
If
you want to attempt the repair yourself please let me know and I will
get you the part number and a place you can purchase it from for what
you need.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
