Hello
To download content from the Cloud:
1.From Home, tap a Kindle content library (for example, Books) in the top navigation, and then tap the Cloud tab to view Kindle content not downloaded to your Kindle device.
2.Tap your content type to download the title to your device.
3.Tap the Device tab to view your Kindle content.
For any help visit us: Kindle com Support
SOURCE: Hello, Whenever I download a
that happens to me sometimes too but you have to choose search google and it should probably work
SOURCE: I have just received (in
How to download books to your Kindle from your computer
We had a reader email us and ask us how he could get a TeleRead-mentioned e-book onto his Kindle. In case anyone else would like a tutorial, here's how to do it.
Download the e-book to your computer. Connect the Kindle to the computer's USB port. The Kindle will show up as a new drive on your computer. If you have an SD card in the Kindle it will show up as a second new drive. Copy, or drag and drop, the e-book to the Documents directory in the Kindle or SD card. That's all there is to it. When you disconnect the Kindle the machine will automatically recognize the new book. Be sure not to disconnect the Kindle until the little silver block at the bottom right stops spinning around.
If you use an SD card, you can dispense with all of the above and just remove the SD card from your Kindle and connect it to a card reader and copy the book directly from your PC to the proper directory on the card. The Kindle will recognize the new book when you plug the card back in. To be safe, shut off the Kindle when removing or inserting the card.
You can also just email it to your kindle's address. Although there is mention of a 10 cent charge per email, no one has ever been charged and Kindle support says there are no plans to do so, at this time.
It's definitely being charged now - I sent a 50 MB PDF to my kindle email address and received a $4 charge.
http://findpdf.net/
and
http://consumerist.com/2009/07/how-to-load-up-your-kindle-with-non-amazon-ebooks.html
SOURCE: Downloading books
If you have the 3G model of Kindle then you can download books using 3G which is like you would use with a mobile phone.
If you don't have 3G then you will need to connect to a WiFi network in order to download books directly to the Kindle. See the Connecting With WiFi Guide for details of how to do so.
You can also transfer books directly from your PC to your Kindle using a USB lead - see the video guide on how to do this.
SOURCE: I want to download book from cd to kindle
To transfer books from CD to your Kindle you will need to use a computer and connect your Kindle to that computer by USB then copy the books from the CD to the Kindle folder that you can find via Windows Explorer.
See the help information for Transferring files via USB on the Kindle Support web site for further details on doing this.
SOURCE: Don't know to use my new kindle
There are many user guides and manuals available for download on the Kindle Documentation Page on Amazon's website. This is probably the best place to start and should have the most information about all models.
