J
Joe Butano Posted on Jul 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon IX7000 blinking alternate amber and green lights Blinking back and forth green and amber lights on the panel. What can I do??
Pamela Leach
Level 3:
  • Canon Master 1,830 Answers
  • Posted on Jul 20, 2017
Pamela Leach
Canon Master
Level 3:
Answers
1830
Questions
5
Helped
368639
Points
7356
Unplug it from the power source, wait a few minutes and then plug it back in.
5 Related Answers
Anonymous
  • Posted on Mar 06, 2008
SOURCE: Light Blinking
you to change printer exober
Anonymous
  • Posted on Feb 26, 2009
SOURCE: Monitor black screen with blinking amber/green light
You need to reset the display. The display is in a safe mode. Resetting the display is a simple procedure and Planar has the instructions on their website in their online customer support section.
Anonymous
  • Posted on Mar 15, 2009
SOURCE: Red light blinking on PS3
If your having this problem I know how to fix it but only for about 30-45 seconds.
Okay this is what you do.
1.If your ps3 is turned on press the red button , it should turn green then yellow ,beep and blink red.
now do this 3 times without turning it off.
2.Turn your ps3 off.
3.Turn it on while holding the eject button.
4.Now your ps3 should stay on ,(like I said for about 30-45 seconds).Also the fan should be on.But then after a while it turns back off.And that's as far as I got.
(It really works if you do it right)
ajx13
Arjun Aukta
  • 110 Answers
  • Posted on Aug 11, 2009
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Anonymous
  • 4323 Answers
  • Posted on Apr 28, 2011
SOURCE: Error Code B200. Blinking
Hi
B200 error code means that the issue is with high temperature of the print head due to voltage issue. Its like the temperature sensor will detect high temperature of the print head and will flash this error code. You can leave it unplugged for 30 minutes and if the error returns then the print head should be replaced or the unit should be serviced. If it requires service then I believe that will not be a better option as it will cost you same as a new unit. Hope this helps...please post back for further assistance.
Daniel
1helpful
Repair ip3680 error
the printer has occurred. error code 006.
My kiaamanti radio lights are blinking on and off like a christmas tree, even when the ignition is off and key is out. how do i correct?
Hi,just food for thought,have you thought abtry,all the out taking the fuse out and leaving it out for 30mins then put the fuse back in,maybe it will right its self worth a try.
5helpful
3answers
My Cannon i860 is blinking an amber light five times and then returns to green then blinks amber five times and so on. What is this error telling me?
I too went through all the cleaning processes on my i860 with its amber light blinking five times to one of green. After all that time and effort, I ordered a new head, replaced it, put the old ink carts back in, and presto, worked like a charm. Don't waste time and money doing anything else.
10helpful
3answers
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
1helpful
I950 printer - middle green light keeps changing to blinking amber color then back to green and does not print. Frank Grande [email protected]
Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The i950 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service.
Copy and paste the link below to locate an authorized service facility and obtain further instructions.
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=232&modelid=8719
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
1helpful
Have just changed refilled cartrige, alarm light is blinking
The printer does a longer green flash and then the amber flashes. you need to tell me how many flashes between the green flashes, to know what the problem is.
2helpful
2answers
Blinking Lights
do this to reset your printer:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
HELP!
Hi taximom, Is the light alternating back and forth between green and orange (GR OR GR OR GR OR GR)? Or is there a pattern like (GR OR OR OR GR OR OR OR GR) or (GR OR OR OR OR OR OR OR OR GR OR OR OR OR OR OR OR OR GR) If it the first case (alternate back and forth) then I hate to be the bearer of bad news but it needs service. (and it's probably not worth fixing) If there is a pattern to the blinking let me know exactly how many times it goes orange and I can tell you what to do from there. The Dude
old marine
old marine
ZJ Limited
ZJ Limited
