The Juki has been in storage for years. I have oiled every oil point. Also, I can only turn the balance wheel when the v-belt is removed.
SOURCE: rethreading my juki overlock
threading industrial overlockers can be very tricky do you not know anyone who ever worked one in a factory because showing is much easier than telling
SOURCE: I have a Juki Lu-562. The safety clutch counter
click this link directly .http://www.raichert.com/adobe/LU562%20LU563.pdf ------ its mentioned on page number 12 of the link.ablout the clutch spring adjustment. --------- check out.keep updated.thanks.
SOURCE: I have a Juki LU-562 sewing machine I was sewing
Like most of the older sewing machines, the lu-562 is usually an easy fix when it comes to issues of timing and even broken parts. First determine where the spring came from and that should point you to the parts that need replacing and/or readjusting. But, by all means DO NOT continue operating the machine until its fixed. Without actually seeing the machine, it sounds as if the needle bar spring failed.
SOURCE: How to check oil for Juki DDL5550-N 7
hi there,regarding after what you can change oil, you can change oil after 8 month.regarding how can you change the oil, please check screw at the right side on the oil pan, remove it and but something under the oil pan to empty the old oil.when you re full oil pan again please check there's tow mark high and low you must make oil is equal with high level.best regards
