SOURCE: tv worked fine last night. tried to turn on today
ONLY 1 or 2 things can cause this problem----First thing to do is
remove front speaker grill--it pulls out and secured with plastic
pegs--behind it you will find an inspection plate---Notice the one or
two pairs of wires coming from the front keyboard
of the set---remove the inspection plate and follow the wires to the
right--you can unplug both plugs(most have two and they are marked with
letters and different sizes so you cannot get them wrong)
The
idea here is to remove the front keyboard with its reset button etc
from the circuit---You will still be able to try to turn the set on
with the remote---these sets have a Receiver(large metal box to the
left as you look from the back) and if the power goes out the green
light will blink for about 70 seconds and then go out---it is the
Receiver booting up.
If disconnecting the keyboard allows the
set to turn on--you have a bad reset switch and two choices---either
operate the set only with the remote or to remove the front screen and
get at the reset switch (it is tiny) and remove and or replace it.
If
disconnecting the keyboard does not restore the set to operation---the
receiver is bad---there are 4 or more caps and some pico fuses that can
fail in that unit---Mitsubishi no longer sells or repairs these--if it
is bad and not the caps there is a company you can send the unit to and
have it repaired--if you need to know their name let me know---you can
call them and get a quote for repairing the receiver.
SD Tech
SOURCE: i connected ps3 to my
The PlayStation Network is down at the moment. Sony Entertainment is working on this. The code is from the site not a physical error with your PS3.
"While we are investigating the cause of the Network outage, we wanted to alert you that it may be a full day or two before we're able to get the service completely back up and running. Thank you very much for your patience while we work to resolve this matter. Please stay tuned to this space for more details, and we'll update you again as soon as we can."
http://blog.us.playstation.com/2011/04/21/latest-update-on-psn-outage/
Regards,
Tony
SOURCE: Hi, I have a transit
I think it is i will probably have to pull the timing belt, it sounds like it probably skipped due to the serpentine belt cords wrapped around something under the timing belt cover, any other suggestions on alternate causes before I start pulling the brand new timing belt?12
SOURCE: Winco WC12000HE won't start...fired up last
Sounds like a fuel problem, check your filter if there is one. Check fuel in tank, make sure there isn't a valve off. Check your choke if you have a manual choke.
Check the Ac power cord,Fuses or the power supply module.
