Question about Science & Laboratory
Pls. I have Sanyo MAC1200 autoclave but I fond it difficult to open the door.kindly assist on how to do this?
    New Friend:
2 Suggested Answers
Anonymous
SOURCE:
bulbpod7
  • 162 Answers
SOURCE: Pls. kindly request help your assistance my
you need the latest internet explorer which is 8
Posted on Feb 27, 2011
Gasket has blown while autoclarve was on a cycle, The door is locked is there any way to open it?
It should be seen by a tech, because he must open the esterilizer to unblock the door and replace the gasket.
Aug 15, 2014 | SciCan Bravo 21V chamber autoclave with...
What is the solution for error 4 appears on autoclave little sister 5
Visually check for obstructions on the door seal area. Clean gasket and its mating face. Run Cycle again.
May 25, 2014 | Science & Laboratory
Error 3
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
Apr 16, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Sanyo mac 1200 autoclave
Clean the chamber with 50x50 water and vinager whith a cloth once a month.
Jan 14, 2014 | Science & Laboratory
3870EA autoclave
Check the rubber door (safety locking device) bellows. If it is cracked it will leak
Aug 23, 2012 | Health & Beauty
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My DVD door will not open. How do I get it open?
MY DVD PLAYER WILL NOT OPEN. IT SAYS THAT THERE IS A DVD INSIDE, BUT I CAN'T GET IT OUT. IT WILL NOT SHOT OFF EITHER.
Mar 11, 2008 | Sanyo DWM400 DVD Player
Science & Laboratory Logo
1,740 people viewed this question
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
