Don't worry I'm sure you will get the solution of your problem, just check the link I attached CLARK FORKLIFT NPR 17 NPR 20 SERVICE REPAIR MANUAL
SOURCE: Make, Model, & Year of Clark Forklift
Contact a Clark Dealer or service center. They can trace the chassis numbers. Don't run it without a plate on it, it's illegal and totally uninsurable.
SOURCE: Forklift hydraulic connections on the mast.
So if you have three cylinders then the extend ports of the cylinders(bottom) should go to the 'A side of the valve and the Rod end or retract (top) should go to the "b" side. The A or B are probably not marked. Each cylinder should go to the valve at the coresponding lever.
Hope this helps you ask again for more..WF Services
SOURCE: tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
SOURCE: clark forklift with error code
The description for code 15 is battery voltage to low. The code will flash when the battery volts are less than 1.95 volts per cell when the key is turned ON. Check the battery voltage with volt meter at battery were positive and negative connect. If the battery is 36 volt it should be no less than 35.1 volts, if the battery is 48 volt it should be no less than 46.8 volts. If battery voltage is low check each cell indavidually to locate a bad cell, each cell should have around 1.95 volts, if a couple are dramatically lower that may be your problem. If the battery checks out check your cables and connections (this seems likely because you say its after you charge battery, when you plug and unplug your battery in you wiggle the cables around witch could cause a poor connection.) Check over your cables carefully as corosion can grow inside of them especially near the battery and connector. Hopefully this helps, looking forward to positive feedback thanks.
SOURCE: clark forklift hydraulic problems
Leaking valve on return line for tilt cylinder, or dirt.debris is keeping the sequencer valve open. The cylinder should be flushed to dislodge any nore. If the cylinder is showing an external leak, it was overloaded at the fork tips, and a seal or the stack ruptured. The valve and lines should also be flushed.
