Looking for the manual for this tv. also i have no remote and am trying to hookup cable but cant access menu options. help.
SOURCE: remote control
The correct model number is iLO2600.. That remote is available at http://www.remotes.com CHEAP!!
SOURCE: ilo tv.
Another possible solution is to go to a major online supplier of replacement remote controls, such as http://www.remotecontrolscenter.com which offers replacement remotes for the ILO brand. I've ordered from the site above, and you will receive the exact replacement that you need for your tv as I did with my sony dvd player.
SOURCE: Pioneer VSX-818V A/V reciever manual
Used the dvr/vcr component hookup as the input for the cable box, and that worked. Pioneer's tech line is virtually no help.
SOURCE: ilo 2600 remote control code
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
SOURCE: access the menu options manually
Press the set's Volume (+) and (-) buttons simultaneously to activate the Menu display. Use the Channel Down button to scroll to the desired menu item, then use Volume (+) or (-) to change that item, or to activate a sub-menu if any. (If in a sub-menu, again use Channel Down to reach the desired item, then Volume (+) or (-) to change its setting or value.) When finished, press Volume (+) and (-) simultaneously as needed to "back out" of the menu.
Not all set functions can be reached this way, especially a few involving numeric entry; but this will get you started. Good luck!
