SOURCE: Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
