SOURCE: cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking
noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal
fault is the natural cause for protect mode. If all the above did not
work, then the problem is a blown component or an internal fault. In
this case the unit must be taken apart , tested and repaired by an
experienced person.
If the unit is less than one year old, or if you
want to get service, call Sony at the phone number listed on the
product documentation.
Regards.
SOURCE: We have a Samsung Digital
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened.
There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system.
Unlocking Procedure 1
To turn off the Dealer
Lock function, follow these
steps:
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2
steps
Note: Repeating
Unlocking Procedure 3
steps
Note: Repeating
the two steps above turns Dealer Lock on again.
Unlocking Procedure 4
steps
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
SOURCE: A DVD is stuck inside the Acura MDX 2005 DVD Player.
look for a small pinhole opening on the face if you find one that is the master reset stick a paperclip into it and ther you go
