SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
SOURCE: Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
Look at this link... it worked for me!!! Basically,
1) Use a heating pad and warm the display.
2) Open the dryer door as well to let the warm air in.
It took about 15 min for me and saved me a over $100 in repair costs.
http://mikemerrittmotors.yuku.com/topic/796/t/Maytag-Neptune-Dryer-Lights-up-8-8-Wont-work.html
SOURCE: Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
SOURCE: KGRA806PSS00
We had the same problem as well. everything locked up and the display board went dead. It turned out to be the thermostat in the back. Once that was replaced everything worked ok. . The serviceman told us to pull the oven out from the wall when self cleaning. It is because the heat disapation and air circulation from the oven is very poor when running at maximum temperatures and this burns out components. First check the termostat, which is a $20.00 item.
SOURCE: how do i get access to gas valve coils on maytag neptune series dryer
Here is a link of an exploded view of a dryer hopefully this can help you! have a good day! Ps don't forget to give me a rating if this was helpful!!! thank you
http://www.repairclinic.com/0100_17.asp
