Televison & Video Logo
T
Tom C Posted on Jul 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
50inch LED LG LN5700uhbusylhr The Screen flashes when i first Turn it on showing me the LG Logo then goes black. i have done the flashlight Test the Screen is Showing up, and showing me the menu.
I Am Getting 84v on both +LED outputs with LED's plugged in. This means it is the LED Strips themselves doesn't it.
Donald Pera Deane
Level 3:
  • LG Master 384 Answers
  • Posted on Jul 27, 2017
Donald Pera Deane
LG Master
Level 3:
Answers
384
Questions
0
Helped
160692
Points
1901
Yes Most Likely The Screen Is Bad i Have Brought a few of them back from the dead but in your case it might just be the right answer (replace the screen) !! Good Luck We Are Here For You!!
Donald Deane MCSE,ASE,CPO
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783170
Points
6681
Hi Tom,
If all the voltages measure as they should, that means the failure is with the LED's strips.
5 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Jan 27, 2010
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
Jay Plesset
  • 2942 Answers
  • Posted on Jan 11, 2016
SOURCE: how do I test the led strips?
LED strips very rarely go out. Check the voltage across the LEDs. More likely power supply is out.
Testimonial: "I GOT IT. ALL I DID WAS JUMP THE LED THAT WENT OUT BY SOLDERING THE + N - TOGETHER AND IT WORKED."
dhopper122
  • 75 Answers
  • Posted on Feb 23, 2016
SOURCE: How do I determine if it's the LED Driver or the LED lights that are bad on my LG LED TV?
If it was the LEDs, then you should still have some working. My first thought would be the LED driver circuits.
Best of luck.
ideaal
Pieter Vleeshouwers
  • 2029 Answers
  • Posted on Jun 06, 2016
SOURCE: black screen
one of the step up transformers on the inverterboard can be blow up in the most bad case that only the ccfl above start then you see also the logo by only the working ccfl lamp on the bottom or on the top , then it fall after someseconds down in protection mode , there can be bad capacitors on that inverterboard or and also in the powerboard that may have leaked or are bulged topped the first thing is to look to pull out for 1 or 2 cm the both ccfl lamps only if its easy to handle. so you can see witch part of the lamps most case the ccfls are placed in groups of 2 lamps on the top of the screen and 2 down on bottom of the screen most case 2 lamps in a rail . 8 wires 4 wires bottom and 4 wires top white blue and or white red colored with little connectors totally then you can see if only one of the lambs in a pair will not start otherwise it is impossible to control or a complete pair will not start . the flashlight test was good so the power supply shall be good function orfor the most things but a fuse resistor can be blowup in the line to the backlight-inverterboard but if you look the capcitors and see 10v dc ones are to find replace them allways for 16v oreven bulged or not they are bad choosen to tight tolerance all bulged ones must replaced with a higher dc 16v if bulged found take 25v ones because of to tight tolerance by factory, sometimes there can be another problem but this can be happen but a very small chance that a suppression coil was not good cleaned in the factory proces and there are 2 of them in the inverterboard to find. because it it happened to me 2 times by brands like acer and fujitsu siemens the models haved both a separate poweradapter so not have its own power supply insite. both of the monitors i have bought in 2006 and 2007 second hand and by both replaced only in the separate powersupply the bad bulged capacitors for other capacitors after but both monitors are have had that supression coils problem inpriority when i bought them both defect come from Germany it started and then it stopped but by manipulation with a plastic object carefully move both coils it was starting again so i cleaned the ends of the wire of the coils and oneofthe coils was not good degummed (not fully stripped of the wire insulation) and the soldering timein factory was a little bit to cold ( to short time heated solder bath proces) look for brown places on the print by some active components that no parts are have also bad solderings.
gopakumarg43
  • 76851 Answers
  • Posted on Oct 08, 2016
SOURCE: LG 50la6970 no backlight i have sound and dark images!
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2answers
1helpful
2answers
Lg 50ln5700 flashes then goes black
Hi Randy,
Since you have replaced all boards and the TV still does not work, The LED's strips have failed and will need to be replaced.
Check the link for more info about how replace the LED strips.
Can someone point me at the blink codes matrix for this LG line?
Check out the inverter board that powers the back light leds.
Best of luck.
Model 55LN5700. Turn on, LG logo pops up, screen goes black. What's wrong?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
