SOURCE: how to unlock ASM in
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
SOURCE: What's the EHT number of sansui TV model sv 2010
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
